Hello,
I have a Fez Spider I and a J11D Ethernet module. My attempts to use a WebClient.GetFromWeb() are met with timeout errors.
A few hundred google searches later I find i’m likely running the wrong TinyBooter and I don’t have the correct MAC addressing in MFDeploy.
Trying to change the network settings in MFDeploy doesn’t work, showing the error “Invalid configuration data from Plug-In”.
When i try to update the TinyBooter using FEZ Config the device manager spits out Unknown USB Device (Configuration Descriptor Request Failed)" for what i think should be a recognized GHI driver.
This is all done on a Windows 10 64-bit desktop PC between 2 different USB cables and a handful of USB ports all with consistent results. Iv’e tried with and without external power supply at 6V also.
MFDeploy Information:
Created EE.
HalSystemInfo.halVersion: 4.3.1.0
HalSystemInfo.halVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
HalSystemInfo.oemCode: 255
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 65535
HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
ClrInfo.clrVersion: 4.3.1.0
ClrInfo.clrVendorInfo: Microsoft Copyright (C) Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.3.1.0
SolutionReleaseInfo.solutionVersion: 4.3.7.10
SolutionReleaseInfo.solutionVendorInfo: Copyright (C) GHI Electronics, LLC
SoftwareVersion.BuildDate: Jul 29 2015
SoftwareVersion.CompilerVersion: 410713
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 320
LCD.Height: 240
LCD.BitsPerPixel: 16
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: True
ProfilingAllocations: True
ProfilingCalls: True
IsUnknown: False
/code]
