I am experiencing frequent BSOD on FEZ Spider.
In order to exclude my project code as cause of the problem I have created a blank project with one line of code :
display_TE35.SimpleGraphics.DisplayText(“TEST”, Resources.GetFont(Resources.FontResources.NinaB), Color.White, 10, 10);
After running the code for some time (10 mins) board hangs with BSOD.
Firmware is 4.2.11.2 both od device and comp and the modules I have connected are : display (te35), usb client DP, ethernet j11d and button.
Any ideas or tips on how to troubleshoot this ? Could it be faulty HW ?
Thanks,
Roman
i don’t know if its part of the problem but i saw the 1/2 first row when i mix up T35 and the TE35 display
Daniel
I would make sure power is not the problem. Use a power pack or a usb hub.
Thanks VB-Daniel - this is most probbably my problem. I had the TE35 in the project while it should have been T35 as you said.
Im testing now - but so far it seems that its working.
Regards
Roman
no - unfortunately still the same thing.
ALthough the first line on the display is now fully visible : ABORT Prefetch.
I also have a power supply - so power should not be the problem.
Any other ideas ?
Tnx
Roman
Reload the firmware maybe
If possible, could you please post your entire test program.
I have updated the TinyLoader to 4.2.11.1 and Firmware to 4.2.11.2 (screenshot)
Still same problem.
I have noticed one thing - when the board hangs red light is turned on the button.
Thanks for help
ROman
how can I upload the solution ?
[quote]In order to exclude my project code as cause of the problem I have created a blank project with one line of code :
After running the code for some time (10 mins) board hangs with BSOD.[/quote]
(1) Please post (to this forum) your complete project C# code.
(2) If you take off all modules except the TE35, does you program reproduce the error.
I have created a blank project with only display_t35 and USBClientDP.
(note its not the TE35 as I previously posted but the T35)
And this also crashes.
Here is the code (everything is default besides the one line that displays TEST on the screen:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace HangTest
public partial class Program
display_T35.SimpleGraphics.DisplayText(“TEST”,Resources.GetFont(Resources.FontResources.NinaB),Color.White,10,10);
Debug.Print(“Program Started”);
Is it easy to shop to us to test for you?
Gus, I could ship it - but since Im in europe they could carge me customs tax (one more time) once you ship it back
I would use this as last option.
Is there anything else I could try ?
Tnx
Roman
If you ordered from a distributor then maybe check with then?
Gus,
I ordered from GHI directly. Can you ping me on my mail directly and point me to someone I can talk to on how to test the item or possibly return to you.
Roman
