I only wanted to ask if this is a known problem using the current .Net 4.2.
I have a Spider application that will run as long as I do NOT connect my auxillary power supply to the USB Client DP.
If I connect the auxillary power supply AND the USB cable at the same time, the Spider keeps resetting in a 'loop".
My ‘gut feel’ is that reinstalling the WinUSB will correct this but I have removed it because my ChipworkX System does not ‘like it’.
I’m now using the USB driver that installs with the current 4.2.
Anybody know if the ‘NEW - waiting for’ 4.2 software will allow both of my boards to run with one USB driver?
I sure hope so! I have just ordered the new FEZ Cobra II (WiFi) and… What USB driver will it want?
Again… This is really not a gripe
However, I would like to be able to use my Spider with the USB for debugging and the AUX power for some additional current.
The 1.2 version of the USB Client DP has an issue when using both auxiliary and USB compliant power sources, and will produce the issue you are seeing, at least in your case.
It only fails when USB voltage and power supply are exact. This is where it gets confused on what source to use. It is extremely rare for this to happen and if it did then a different port or a hub will fix the matching.
This was fixed months ago and 1.3 ships since then.
