I’ve just realized that the rhino oem kit is retired…
What a pity!
Now developing a simple project with an ethernet socket, an sd card, a display and an usb client seems to be more expensive and there is not an equivalent kit that includes a similar box…
Uhm…
I am wrong… Not more expensive using panda II or domino. But there is not a kit with such a beautiful box (except for the cobra box, that is more expensive).
Yeah, the problem is this: the spider is a very powerfull board, but it can be use only for prototypes… The rhino kit was a good solution for a final product.
We give you the design files + the chipset needed. So, you can make it if you want. GHi can also make special runs for you (with volume) as well. It is just not an off-the-shelf item anymore.
