Attached code shows the problem. I have no idea what is going on or how to correct it.
using System.Collections;
using Microsoft.SPOT.Touch;
using GT = Gadgeteer;
using GHI.Usb.Host;
Using VS 2012 For Desktop on Windows 8.1 with all the latest updates
Using FEZ Raptor Rev 1.0 with G400-S V1.1
usbHost Socket 7
usbClientDP Socket 8
namespace G400test
public partial class Program
usbHost.MassStorageMounted += usbHost_MassStorageMounted;
usbHost.MassStorageUnmounted += usbHost_MassStorageUnmounted; // This causes NULL exception
Debug.Print("** Program Started");
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
Using mainboard GHI Electronics FEZ Raptor version 1.0
** Program Started
** usbHost MassStorageMounted
The thread '<No Name>' (0x3) has exited with code 0 (0x0).
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (4) ####
#### Message:
#### GHI.Usb.Host.BaseDevice::OnDisconnected [IP: 0017] ####
#### GHI.Usb.Host.Controller::OnDisconnect [IP: 002b] ####
#### GHI.Utilities.InternalEvent::RaiseEvent [IP: 000d] ####
#### GHI.Utilities.InternalEvent::OnEvent [IP: 0035] ####
A first chance exception of type 'System.NullReferenceException' occurred in GHI.Usb.dll
An unhandled exception of type 'System.NullReferenceException' occurred in GHI.Usb.dll
void usbHost_MassStorageUnmounted(USBHost sender, EventArgs e)
//Added try/catch but NULL error is received before this method is entered?
try
Debug.Print("** usbHost MassStorageUnmounted");
catch (System.NullReferenceException err)
Debug.Print(err.Message);
//Called on program startup if Flash is already inserted //No exception received
//Called after program startup when Flash is inserted //No exception received
void usbHost_MassStorageMounted(USBHost sender, GT.StorageDevice device)
Debug.Print("** usbHost MassStorageMounted");
I must mention that the VS 2012 Express For Desktop on Windows 8.1 was installed after my recent purchase of Visual Studio 2013 Pro. I had removed all Express versions I had before installing 2013 Pro. After it was installed I downloaded and installed it Express 2012.
I only mention this because debugging seems a bit different than when I only had the VS 2012 Express.
It appears to me that VS 2012 Express For Desktop is somehow tied into my Full version of 2013 Pro. Maybe not but I think so…
Thanks for any thoughts on why I get this null exception
EDIT:
I forgot to mention that if I have button events… And use Controller
Controller.DeviceConnectFailed += Controller_DeviceConnectFailed;
Controller.Start();
I no longer receive the events…
