What is the overall specified range for setting the SPI clock rate on the Raptor? I have need for a low rate (~200kHz), but anything lower than about 525 kHz seems to break the interface.
Here’s the code I’m using to test:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Gadgeteer.Interfaces;
using GTI = Gadgeteer.Interfaces;
namespace SPITest
public partial class Program
private GT.Socket SPI_socket;
private GT.Socket IO_socket;
private GTI.SPI mySPI; // Syncport Module A
// Define the SPI Configuration object
private static SPI.Configuration spi_configuration = new SPI.Configuration(
false, //Chip Select Active State
0, //Chip Select Setup Time
0, //Chip Select Hold Time
false, //Clock Idle State
true, //Clock Edge
525); //Clock Rate (kHz)
// Define Module BUS Read Signal
private static DigitalOutput Trigger;
public static byte[] spidata;
const int bufferLength = 32;
timer.Tick +=<tab><tab>
timer.Start();
// Define the SPI Interface
SPI_socket = GT.Socket.GetSocket(1, true, null, null);
mySPI = new SPI(SPI_socket, spi_configuration, SPI.Sharing.Shared, SPI_socket, GT.Socket.Pin.Six, null);
// create and fill the SPI data buffer
spidata = new byte[bufferLength];
for (int i = 0; i < spidata.Length; i++)
spidata[i] = (byte)i;
Trigger = new DigitalOutput(SPI_socket, GT.Socket.Pin.Five, false, null);
timer.Tick += timer_Tick;
timer.Start();
Trigger.Write(true); // Fire Trigger pulse
mySPI.Write(spidata); // send the SPI buffer
Trigger.Write(false); // Reset trigger
