Got my raptor a few days back and besides pushing a button and getting some leds on and off, totally newby with Gadgeteer en netmf.
I started playing around with the sercam and display today following the developers guide on the sercam product page. I keep getting slapped with error from the sercam;
I downloaded the sourcecode from codeplex and referenced it in my solution > no luck
I see quite some tutorials referencing the sercam mentioning events like StartDataCaptured but in my solution (referencing latest code from codeplex) no events to be found
The T43 display just sits there show so basic text data > Is that normal?
All seems correctly connected > at least to my humble experience up to now…
Maybe I am doing it completely wrong so please excuse me for the newbie questions
Read the getting started guide for the Spider located on the disk where you installed the GHI SDK. On my machine, it is located at C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Getting Started Guides. It is an example with the camera.
The guide uses the Camera 1.1 module while I have the SerCam v1.0. Methods avaialble to the camera module in guide are not available in the sercam module…
Disconnecting the T socket worked.
Strange though that you need to disconnect a socket on one module to get another module to work…
Are there any updates planned to fix the issue?
Thanks!
@ Dat - not sure on the strangeness of things but seeing my newbie status I’ll take it as answer for now
Can I download the fix from codeplex? As such the sercam will function with the T socket connected? Kind of need it to fit in an app that of course needs the touch function on the display to work.
