I’ll start by saying that the firmware is not what the factory loads.
I had to reinstall the firmware because I trashed it somehow.
I used the G400 firmware because I know of no new firmware for Raptor.
That said…
My problem is that I receive a exception if I use:
private static PersistentStorage pS;
pS = new PersistentStorage(“SD”);
using System.Collections;
using Microsoft.SPOT.Touch;
using System.IO;
using System.Text;
using Microsoft.SPOT.IO;
using GHI.Premium.IO;
using GHI.Premium.Hardware;
using GHI.Premium.System;
using Gadgeteer.Networking;
using GT = Gadgeteer;
// FEZ Raptor using firmware G400 4.2.11.0
// VS2012 express using .NET Micro framework 4.2
// Windows 8 64bit
// App to show exception using PersistentStorage
// Has assemblies:
// GHI.Premium.Hardware, GHI.Premium.IO, GHI.Premium.System, System.IO, Microsoft.SPOT.IO.
namespace RaptorShowSDError
public partial class Program
private static VolumeInfo vI;
vI = VolumeInfo.GetVolumes()[0]; //No exception
try
pS = new PersistentStorage("SD");
catch (System.Exception se)
Debug.Print("Debug Output: " + se.Message);
Using mainboard GHI Electronics FEZRaptor version 1.0
Program Started
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1) ####
#### Message:
#### GHI.Premium.IO.PersistentStorage::.ctor [IP: 0000] ####
#### RaptorShowSDError.Program::ProgramStarted [IP: 0017] ####
A first chance exception of type 'System.InvalidOperationException' occurred in GHI.Premium.IO.dll
Debug Output: Exception was thrown: System.InvalidOperationException
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### RaptorShowSDError.Program::ProgramStarted [IP: 0037] ####
A first chance exception of type 'System.NullReferenceException' occurred in RaptorShowSDError.exe
An unhandled exception of type 'System.NullReferenceException' occurred in RaptorShowSDError.exe
pS.MountFileSystem();
Any info appreciated.
Baby sitting so not sure when I’ll be back… Maybe tonight…
Thanks!
