First of all thank you for this wonderful community !
I have a USB host and a memory stick and a FEZ Raptor…
how can i connect and create files into the usb stick ?
i have seen many examples, but what is the difference between PersistantStorage, Removable Media ?
Welcome to the community and thank you for the comment!
For your specific usage, you will not need to use either one of those classes. With the USB host module, you will interface the module itself for device connected events etc.
string root;
timer.Tick +=<tab><tab>
timer.Start();
usbHost.USBDriveConnected += usbHost_USBDriveConnected;
void usbHost_USBDriveConnected(UsbHost sender, GT.StorageDevice storageDevice)
root = storageDevice.RootDirectory;
FileStream file = new FileStream(root + "\\file.txt", FileMode.OpenOrCreate);
