I’m trying to get some network stuff up and running on the Raptor.
Seems no matter what I do, .NET/libraries keeps using the first interface when it does network stuff. Where the first interface available is the internal on-chip stuff that’s not available on the Raptor.
The second is the ENC28 and 3th is WiFi from what I can find out.
I want the network stack to use the ENC28 as my “default” network adapter so stuff that uses network and assume/take the default/first adapter could work. Seems like it always picks the 1st adapter right now - while the 2nd (Ethernet module) is the one I want it to use.
When debugging, the socket (or other network related stuff I’ve been testing) has local endpoint set to 0.0.0.0:0
Could anyone point me in the right direction?
Program.cs
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.Text;
using Gadgeteer;
using GHI.Premium.Net;
using Gadgeteer.Modules.Seeed;
using System.Net;
using System.Net.Sockets;
namespace GadgeteerApp1
public partial class Program
// static EthernetENC28J60 Eth1;
// ********** G400 Raptor socket 1
// public static EthernetENC28J60 Eth1 = new EthernetENC28J60(SPI.SPI_module.SPI2, GHI.Hardware.G400.Pin.PB5, GHI.Hardware.G400.Pin.PB0, GHI.Hardware.G400.Pin.PA7, 4000);
// public static Ethernet_ENC28 Eth1 = new Ethernet_ENC28(1);
public static ManualResetEvent NetworkAvailablityBlocking = null;
static string _repeaterIp = "10.0.0.216";
static string _boardIp = "10.0.0.217";
static string _boardNetmask = "255.255.255.0";
static string _boardGw = "10.0.0.2";
var timer = new GT.Timer(500);
timer.Tick += timer_Tick;
timer.Start();
Thread initThread = new Thread(new ThreadStart(InitDevices));
initThread.Start();
// private static WebServer webServer;
System.Net.Sockets.Socket socket_30003;
private void InitDevices()
StartEthernet();
EndPoint remoteEndPoint = new IPEndPoint(IPAddress.Parse(_repeaterIp), 30003);
EndPoint localEndPoint = new IPEndPoint(IPAddress.Parse(_boardIp), 30003);
socket_30003 = new System.Net.Sockets.Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
socket_30003.Bind(remoteEndPoint);
if (socket_30003.Poll(-1, SelectMode.SelectRead))
byte[] inBuf = new byte[socket_30003.Available];
int count = socket_30003.ReceiveFrom(inBuf, ref remoteEndPoint);
Debug.Print(new String(Encoding.UTF8.GetChars(inBuf)));
// public static void StartEthernet(EthernetENC28J60 eth)
void StartEthernet()
// Eth1.Open();
ethernet_ENC28.Interface.Open();
// NetworkInterfaceExtension.AssignNetworkingStackTo(Eth1);
NetworkInterfaceExtension.AssignNetworkingStackTo(ethernet_ENC28.Interface);
// Eth1.CableConnectivityChanged += new EthernetENC28J60.CableConnectivityChangedEventHandler(Eth1_CableConnectivityChanged);
// Eth1.CableConnectivityChanged += new EthernetBuiltIn.CableConnectivityChangedEventHandler(Eth1_CableConnectivityChanged);
ethernet_ENC28.Interface.CableConnectivityChanged += Interface_CableConnectivityChanged;
// Eth1.NetworkAddressChanged += new NetworkInterfaceExtension.NetworkAddressChangedEventHandler(Eth1_NetworkAddressChanged);
ethernet_ENC28.Interface.NetworkAddressChanged += Interface_NetworkAddressChanged;
// Eth1.NetworkInterface.EnableStaticIP(_boardIp, _boardNetmask, _boardGw); // class C net
string[] DnsAddresses = new string[] { "10.0.0.2", "8.8.8.8" }; //Test so hardwired in code
// Eth1.NetworkInterface.EnableStaticDns(DnsAddresses);
ethernet_ENC28.Interface.NetworkInterface.EnableStaticDns(DnsAddresses);
// Eth1.NetworkInterface.PhysicalAddress = new byte[] { 0x00, 0x21, 0x03, 0x00, 0x00, 0x0B }; // test MAC
ethernet_ENC28.Interface.NetworkInterface.PhysicalAddress = new byte[] { 0x00, 0x21, 0x03, 0x00, 0x00, 0x0B }; // test MAC
// if (!Eth1.IsCableConnected)
if (!ethernet_ENC28.Interface.IsCableConnected)
NetworkAvailablityBlocking = new ManualResetEvent(false);
do
Debug.Print("Ethernet cable is not connected yet.");
break;
while (!NetworkAvailablityBlocking.WaitOne(5000, false));
while (IPAddress.GetDefaultLocalAddress() == IPAddress.Any)
Debug.Print("IP address is not set yet.");
Debug.Print("IP address is set");
void Interface_CableConnectivityChanged(object sender, EthernetENC28J60.CableConnectivityEventArgs e)
// static void Eth1_CableConnectivityChanged(object sender, EthernetENC28J60.CableConnectivityEventArgs e)
//static void Eth1_CableConnectivityChanged(object sender, EthernetBuiltIn.CableConnectivityEventArgs e)
Debug.Print("Built-in Ethernet Cable is " + (e.IsConnected ? "Connected!" : "Disconnected!"));
if (e.IsConnected)
if (NetworkAvailablityBlocking != null)
NetworkAvailablityBlocking.Set();
// restart tcp listner thread
//StartEthernet();
Thread.Sleep(5000);
PowerState.RebootDevice(false);
//SMSHttpListenerThread = new Thread(new ThreadStart(TcpThreadManager));
//SMSHttpListenerThread.Start();
void Interface_NetworkAddressChanged(object sender, EventArgs e)
// static void Eth1_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("New address for The built-in Ethernet Network Interface ");
Debug.Print("Is DhCp enabled: " + ethernet_ENC28.Interface.NetworkInterface.IsDhcpEnabled); // Eth1.NetworkInterface.IsDhcpEnabled);
Debug.Print("Is DynamicDnsEnabled enabled: " + ethernet_ENC28.Interface.NetworkInterface.IsDynamicDnsEnabled); // Eth1.NetworkInterface.IsDynamicDnsEnabled);
Debug.Print("NetworkInterfaceType " + ethernet_ENC28.Interface.NetworkInterface.NetworkInterfaceType); // Eth1.NetworkInterface.NetworkInterfaceType);
Debug.Print("Network settings:");
Debug.Print("IP Address: " + ethernet_ENC28.Interface.NetworkInterface.IPAddress); // Eth1.NetworkInterface.IPAddress);
Debug.Print("Subnet Mask: " + ethernet_ENC28.Interface.NetworkInterface.SubnetMask); // Eth1.NetworkInterface.SubnetMask);
Debug.Print("Default Getway: " + ethernet_ENC28.Interface.NetworkInterface.GatewayAddress); // Eth1.NetworkInterface.GatewayAddress);
Debug.Print("Number of DNS servers:" + ethernet_ENC28.Interface.NetworkInterface.DnsAddresses.Length); // Eth1.NetworkInterface.DnsAddresses.Length);
// for (int i = 0; i < Eth1.NetworkInterface.DnsAddresses.Length; i++)
// Debug.Print("DNS Server " + i.ToString() + ":" + Eth1.NetworkInterface.DnsAddresses[i]);
for (int i = 0; i < ethernet_ENC28.Interface.NetworkInterface.DnsAddresses.Length; i++)
Debug.Print("DNS Server " + i.ToString() + ":" + ethernet_ENC28.Interface.NetworkInterface.DnsAddresses[i]);
Debug.Print("----------------------------------------------");
private void NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("Network Address Changed");
Mainboard.SetDebugLED(true);
Thread.Sleep(50);
Mainboard.SetDebugLED(false);
Program.generated.cs
// <auto-generated>
// This code was generated by a tool.
// Runtime Version:4.0.30319.17929
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
namespace GadgeteerApp1 {
using Gadgeteer;
public partial class Program : Gadgeteer.Program {
/// <summary>The UsbClientDP module using socket 8 of the mainboard.</summary>
private Gadgeteer.Modules.GHIElectronics.UsbClientDP usbClientDP;
/// <summary>The CellularRadio module using socket 4 of the mainboard.</summary>
private Gadgeteer.Modules.Seeed.CellularRadio cellular;
/// <summary>The SDCard module using socket 9 of the mainboard.</summary>
private Gadgeteer.Modules.GHIElectronics.SDCard sdCard;
/// <summary>The Ethernet_ENC28 (Premium) module using socket 1 of the mainboard.</summary>
private Gadgeteer.Modules.GHIElectronics.Ethernet_ENC28 ethernet_ENC28;
/// <summary>This property provides access to the Mainboard API. This is normally not necessary for an end user program.</summary>
protected new static GHIElectronics.Gadgeteer.FEZRaptor Mainboard {
get {
return ((GHIElectronics.Gadgeteer.FEZRaptor)(Gadgeteer.Program.Mainboard));
set {
Gadgeteer.Program.Mainboard = value;
/// <summary>This method runs automatically when the device is powered, and calls ProgramStarted.</summary>
public static void Main() {
// Important to initialize the Mainboard first
Program.Mainboard = new GHIElectronics.Gadgeteer.FEZRaptor();
Program p = new Program();
p.InitializeModules();
p.ProgramStarted();
// Starts Dispatcher
p.Run();
private void InitializeModules() {
this.usbClientDP = new GTM.GHIElectronics.UsbClientDP(8);
this.cellular = new GTM.Seeed.CellularRadio(4);
this.sdCard = new GTM.GHIElectronics.SDCard(9);
this.ethernet_ENC28 = new GTM.GHIElectronics.Ethernet_ENC28(1);
