HI can i have wifi on a fez panda 2
Welcome to the forum!
Yes you can, You will need this module:
[quote]Welcome to the forum!
http://www.ghielectronics.com/catalog/product/282
[/quote]
@ Architect I think you missed that the board is FEZ panda. This module does not work with FEZ Panda II.
@ Joe
But it should work if it is connected directly to SPI pins on Panda II?
Using one of these methods:
- split gadgeteer cable and solder male pins
- duinoproto shield
- extender/makerbread module
There is no wifi stack on panda like there is on spider. You need a module that is a serial wifi bridge.
Or use the wifi Ethernet bridge with fez connect shield.
Right, missed that completly :-[
