Gentlemen
I create, build and test a small application on my Panda II, it works fine on my Windows 8 PC with VS 2012 in the Debug Mode.
If I stop the Debug Mode in VS, the application doesn’t worky anymore, a reset via reset button, disconnect the USB cable and reconnet or connect to a external power supply, nothing helps.
Also I tried to deploy the “Release”-Version of my application, it was not possible, an error during the deployment comes up.
I remember, I had the same issue with a FEZ Cerbuino Bee, but after some minutes on a external power supply, the FEZ Cerbuino Bee starts to work.
Did I some wrong configurations in VS ?
Thanks a lot for your support.
Regards
Josch.
