Is it possible to use the ADC of the fez panda to sample voltages at intervals less than 1 millisecond?
I’m working on a project to store sound from a microphone onto a file on an SD card that is inserted in the Panda’s SD card slot. However, my initial attempt at sampling the voltages from the microphone every so often using ‘Thread.Sleep(int)’ seems to restrict me from getting samples at intervals less than 1 millisecond.
I tried removing the sleep thread. I figured this would make the ADC sample as fast as it can. However, it only samples at 400 Hz when this is done. Is it possible to achieve faster sampling speeds on the fez panda?
