I’m currently trying to log data from UART (without HW or SW flow control) using 921 600 baud rate, odd parity. Current byte rate is about 15 000 bytes/s, problem is that i miss about 50% of messages (lenght of one is 30 bytes). Is there anyone that was dealing with this kind of problem ?
Your question is missing one or more of these details:[ul]
The name of the product.
The code you’re trying to run.
Details on your setup.[/ul]
(Generated by QuickReply)
Sorry Mike for incomplete question, here reader code that i’m using to read data and write them to SD, there is no code for SD card initialization (different class).
using System.IO.Ports;
using System.IO;
using Microsoft.SPOT.IO;
namespace UARTReader
public class App
private OutputPort m_led = new OutputPort((Cpu.Pin)GHIElectronics.NETMF.FEZ.FEZ_Pin.Digital.LED, false);
private SerialPort m_serial = new SerialPort("COM1", 921600, Parity.Odd);
private const int MessageLenght = 30;
private const byte MessageStartByte = 0x83;
private byte[] m_Buffer;
private int m_counter;
private int m_messageCounter;
private TimeSpan m_RecordStart;
public void Run()
bool headerMatch = false;
byte[] oneByte = new byte[1];
m_counter = 0;
m_Buffer = new byte[1024];
using (FileStream file = new FileStream(GetLogFileName(), FileMode.Create))
using (m_serial)
m_serial.Open();
m_serial.DiscardInBuffer();
while (!headerMatch)
m_serial.Read(oneByte, 0, 1);
if (oneByte[0] == MessageStartByte)
m_serial.Read(m_Buffer, 0, 29);//dočtení jedné věty
headerMatch = true;
break;
m_RecordStart = Utility.GetMachineTime();
int dataCount = 0;
m_led.Write(false);
dataCount = m_serial.BytesToRead;
m_serial.Read(m_Buffer, 0, dataCount);
file.Write(m_Buffer, 0, dataCount);
m_counter = m_counter + 1;
m_messageCounter = m_messageCounter + 4;
m_led.Write(true);
if (m_counter > 1000)
file.Flush();
m_counter = 0;
if (m_button.Read())
break;
m_led.Write(false);
m_RecordStart = Utility.GetMachineTime() - m_RecordStart;
Debug.Print("Recorded " + m_messageCounter.ToString() + ", time span=" + m_RecordStart.Hours.ToString()
+ ":" + m_RecordStart.Minutes.ToString() + ":" + m_RecordStart.Seconds.ToString() + "." + m_RecordStart.Milliseconds.ToString());
/// <summary>
/// Returns file name like \SD\000_rawdata.txt
/// </summary>
/// <returns></returns>
private string GetLogFileName()
//code made shorter(not important part)
return @ "\SD\000_rawData.txt";
As Eric said, you might have an issue at that high of a baud rate…
The first I would do is add a SerialErrorReceivedEventHandler, and see if you are getting overrun errors. If
you are, then you might have to consider splitting off the file writing into a separate thread and/or using
DataReceived event.
and you should read the throughput threads on here about SD card writing. They may also have something to think about in them… http://www.tinyclr.com/forum/topic?id=1858 is a good start on benchmarking.
If writting to SD card is to slow(open file, write small data, flush data and close file, flush file system) you have option to “save” data from serial port to Queue and then in another thread write to file. Im using this way in my logging system because if I direct write to SD card I get corupted LOG file, missing lines, because I write to log from different threads…
@ Dejan - will try your solution, but as Gus stated it might not handle such amount of data.
@ Brett - Well I’have done some test about writing data to SD, per 1 second source generates 15 000, which are stored in about 120 ms.
@ Mike - Well so far I know that the baud rate is high, but I need to store those data for one of my projects.
@ ransomhall - As Gus stated, It can handle that baud rate.
@ Gus - Problem with ALFAT is that our source of serial data is a black box for us, and we need a logger to read incomming data after power on to file with index (like 000_data.txt, 001_data.txt, etc.) Could be ALFAT programmed / configured to do such kind of action without specifing any commands ?
Well we need logging only for few months, and just about 5 pieces. What about using some more powerful FEZ, what you think Gus ? Could it make some difference ? Hydra, ChipworkX ?
Larger devices are a bit faster but not enough for 100% but the good news is that they have a LOT of ram. You can buffer your data in RAM in a huge buffer and write when data is not coming in.
@ Gus - So for example using Hydra and recording 15 minutes (about 8 MB) to RAM and storing data ? I’m not sure how long it would take to store 8 MB of data, but I suppose it would take a while…and the other problem is that data are comming every 2 ms from source, so I suppose that would be much time for writing data.
@ Dejan - Well I switched to FEZ Hydra (more powerful and more RAM), and copying data from serial buffer works fast, so no buffer overflow at all. But when I start to write to FileStream, I see multiple data overflows per second. So I have to change strategy of storing data to SD card or making storing of data faster. So here comes WouterH with his RLP solution. But so far I have to digg in to FAT library and writing data to SD card on FEZ Hydra to try to speed up storing process.
But still, thank you all for ideas, code example and support, really appreciate that!
