I want to assemble robot using Fez Panda , I thinking to buy
These chassis
http://www.robotshop.com/dagu-rover-5-2wd-tracked-chassis-3.html
And this motors controller board
http://www.robotshop.com/dagu-4-channel-brushed-dc-motor-controller-2.html
How easy do you think is going to integrate motor controller with the Panda board ?
Davef
2
You could try here for ideas.
Dave.
Hello
It should be easy
I did purchase a Pololu base and build my own shield for the Panda 2 using this motor driver fromSparkfun : http://www.sparkfun.com/products/9457
I also added this Pololu reflector sensors Pololu - QTR-8A Reflectance Sensor Array connected to Panda II analog inputs
Here is the result
https://www.youtube.com/watch?v=KDKY5knWRVg
