I would like to build a wireless network of LED boxes using FEZ Panda and the PhidgetLED-64 board.
Description of the PhidgetLED-64 board is found here:
The idea is to have a small show with each LED box executing a program independently.
A typical LED box would be:
A FEZ Panda board connected the PhidgetLED-64 board via USB.
A wireless shield mounted on the FEZ Panda.
A 12V power battrey supply.
A program is loaded via wireless to the FEZ Panda.
To run the show:
Make sure all boxes are switched on and listening.
Computer sends a start signal to the boxes and the program of each LED box starts executing.
What do you think? Is this project achievable? Any advice from your experience?
You would normally use that board if you are using a PC so you can control LEDs. You can control LEDs directly with panda, unless you have some high current LEDs?
I do understand that PhidgetLED-64 is normally controlled by a PC. However, using FEZ Panda is impossible to control it or it is something you should not do?
