I am basically a software guy and new to the electronics world so please do not mind my simple questions and tell me things even it is very basic.
I bought FEZ Panda 2 few days back and started with the basic tutorials on the site such as
Digital Output - http://wiki.tinyclr.com/index.php?title=Digital_Outputs
Digital Input - http://wiki.tinyclr.com/index.php?title=Digital_Inputs_-_Buttons
The problem started when I tried the code from the tutorial
USB Debugging with Virtual COM Channel - http://wiki.tinyclr.com/index.php?title=USB_Client
I installed the drivers as per told in the article and then panda just stopped working. I changed the code to debug.Print only and tried to deploy again but VS2010 did not allow me. I searched on the forums and someone pointed that i should ping the device. At that time i was able to ping the device and check the device capabilities as well.
After that i tried to erase the program and then everything stopped working. Now even if i try to ping the device using MFDeploy, MFDeploy will get hanged. Same thing will happen if i try to do anything else using MFDeploy e.g. Device Capabilities.
Visual Studio Compile Error.:
An error has occurred: please check your hardware.
TinyCLR Error
An exception occurred while attempting to launch the debugger: DebugPort.GetDeviceProcess() called with no argument
Check the screenshot of MFDeploy in hanged state. Please suggest how to bring back the Panda 2 to its original state.
Thanks in advance
