I wrote dome code for the Domino that simply reads voltages coming into the analogue pin An1.
I now want the same simple code to work with the FEZ mini. The problem I have encountered is that the deployment always crashes, and hangs until I quit deployment:
[italic]
Device not found or cannot be opened - USB:USBizi========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
[/italic]
However it does in fact seem to deploy to the FEZ mini. Anyone come across this problem?
Are you going into Project->Properties and changing how the project is deployed (last tab). You’ll need to set that to the Mini. Also you will need to change your FEZ domino reference to FEZ Mini.
