I am new at FEZ (had it yesterday). Today, I want to write a program making LED blinking. I have no problem at source code. But, deployment has a problem. It says:
[italic]“An error has occurred: please check your hardware”[/italic]
I tried many ways and searched internet to fix this issue. Still, I can not solve. Used softwares: VS 2010
Microsoft NETMF 4.1 SDK
GHI NETMF 4.1 SDK
Your firmware may be out of date. If you just downloaded GHI NETMF recently it will be version 4.1.3.0. … Your mini may have 4.1.1.0 so you need to check it here
[url]- YouTube
you might be looking at the wrong information. You need to watch the videos on upgrading your Fez Firmware that Ian pointed to and make sure the GHI SDK readme version info matches the device capabilities reported version, 4.1.3.0 is the latest that has only recently been released. It’s critical that they match. Come back and tell us once you’ve confirmed they do match (or updated the device so that they do).
Do you mean it works before you add GHI assemblies and doesn’t work after you add the GHi assembly?
If so, see this http://www.tinyclr.com/forum/1/1562/
