Hi all,
is there any reason why I would not be able to control a servo directly from my FEZ mini board without the use of a breakoutboard etc. I will supply external voltage to the servo, but I want to connect the servo signal line directly to a PWM pin on my FEZ Mini.
I am building a weight critical project and I don’t want additional interface boards where they are not required.
I get the coding part. My question is more about the circuit wiring.
Are the digital outputs on the FEZ mini open collector?
I.E. Do I need a pull up or pull down resistor or are these supplied internal to FEZ Mini? I don’t want to make use of any shealds, and will be making my own Interface board for use in my project.
What value should an ideal pull up/don resistor be?
