I’m trying to communicate to a telit gsm module over COM3 on my FEZ Mini. COM1 is used for Debugging, COM2 for talking to a GPS module (works fine). I had to install a level shifter that the communication with the Telit module works (3,3 <–> 2,8 V). When I’m talking over a TTL to USB Module to the Telit Module everything works fine. Now I just soldered the module to my COM3 but the Communication doesn’t work. I’m always getting back what I sent out.
I tried it but there is no “OK” following,
normally if the “AT#SHDN” Command was sent, the module should turn off, but it stays on…
I suggest that the command is kind of looped back, the only problem could be the level converter, but it is sourced with 3,3V on the side of the FEZ Mini which should be perfect. And it works with the FTDI…
you talked “loopback” which to me really implies that you have a solder bridge somewhere between RX and TX pins. Can you continuity test between them to see if they appear connected?
