EDIT:
I am sorry that my question is posted here… My fault. I have no idea why I put it here.
As usual… My bags are packed, I have the ticket, but my ship has already left port…
Having a bit of a problem creating a Serial port. (For the moment only Writing a test string)
Using Socket 4 Pin 4, CDBUS 0 - TX
Using Socket 4 Pin 5, CDBUS 1 - RX
Using a Breadboard X1 to read Socket 4 Pins 4&5.
No output seen
My guess is that I need to do something with ftd2xx_net.ftdi.ft_cbus_options but I have no idea what I should be doing to set the I/O.
A Bit long but what I have so far: The code is mostly code I found at FTDI
using FTD2XX_NET;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
FEZ Lynx S4 1.0
FTDI created ports - A,B,C,D
devices {FTD2XX_NET.FTDI.FT_DEVICE_INFO_NODE[4]}
FTD2XX_NET.FTDI.FT_DEVICE_INFO_NODE[]
Device Manager shows - Ports(COM & LTP)
USB Serial Port (COM4) Location: on USB Serial Converter A
USB Serial Port (COM5) Location: on USB Serial Converter B
USB Serial Port (COM6) Location: on USB Serial Converter C
USB Serial Port (COM7) Location: on USB Serial Converter D
namespace FEZLynx
class Program
static Timer timerWrite = null;
static FTDI.FT_STATUS status;
static FTDI lynx = null;
static uint written = 0;
static string TextContent = "This is a test string to be written\r\n";
static void Main(string[] args)
lynx = new FTDI();
uint numDevices = 0;
status = FTDI.FT_STATUS.FT_OK;
status = lynx.GetNumberOfDevices(ref numDevices);
if (status != FTDI.FT_STATUS.FT_OK)
Console.WriteLine("Failed to get number of devices (error " + status.ToString() + ")");
Console.ReadKey();
return;
Console.WriteLine(" Found " + numDevices.ToString() + " devices");
FTDI.FT_DEVICE_INFO_NODE[] devices = new FTDI.FT_DEVICE_INFO_NODE[numDevices];
status = lynx.GetDeviceList(devices);
Console.WriteLine("Failed to get the list of devices (error " + status.ToString() + ")");
Console.ReadKey();
return;
//Should always be 4
Console.WriteLine(" Found " + devices[0].Description);
Console.WriteLine(" Found " + devices[1].Description);
Console.WriteLine(" Found " + devices[2].Description);
Console.WriteLine(" Found " + devices[3].Description);
//Storage for device info list
FTDI.FT_DEVICE_INFO_NODE[] DeviceList = new FTDI.FT_DEVICE_INFO_NODE[numDevices];
Console.WriteLine("");
status = lynx.GetDeviceList(DeviceList);
if (status == FTDI.FT_STATUS.FT_OK)
for (UInt32 i = 0; i < numDevices; i++)
Console.WriteLine("Device Index: " + i.ToString());
Console.WriteLine("Flags: " + String.Format("{0:x}", DeviceList[i].Flags));
Console.WriteLine("Type: " + DeviceList[i].Type.ToString());
Console.WriteLine("ID: " + String.Format("{0:x}", DeviceList[i].ID));
Console.WriteLine("Location ID: " + String.Format("{0:x}", DeviceList[i].LocId));
Console.WriteLine("Serial Number: " + DeviceList[i].SerialNumber.ToString());
Console.WriteLine("Description: " + DeviceList[i].Description.ToString());
Console.WriteLine("Press a key to continue");
Console.ReadKey();
// FT4232 Bus available ADBUS, BDBUS, CDBUS, DDBUS
//Socket 4 S/X
//CDBUS0, Pin38, CD0/TX, Socket 4 Pin 4 - output
//CDBUS1, Pin39, CD1/RX, Socket 4 Pin 5 - input
status = lynx.OpenByDescription(devices[2].Description);
Console.WriteLine("Failed to open device C (error " + status.ToString() + ")");
Console.ReadKey();
return;
Console.WriteLine("Opened device C " + devices[2].Description);
// Not all is needed but I will set anyway
//Set the speed
status = lynx.SetBaudRate(9600);
Console.WriteLine("Failed to set Baud rate for device C (error " + status.ToString() + ")");
Console.ReadKey();
return;
Console.WriteLine("Set Baud rate for device C to 9600");
//Set Characteristics
status = lynx.SetDataCharacteristics(FTDI.FT_DATA_BITS.FT_BITS_8,
FTDI.FT_STOP_BITS.FT_STOP_BITS_1,
FTDI.FT_PARITY.FT_PARITY_NONE);
Console.WriteLine("Failed to set DataCharacteristics for device C (error " + status.ToString() + ")");
Console.ReadKey();
return;
Console.WriteLine("Set DataCharacteristics for device C to DataBits 8, StopBits 1, Parity None");
//Set flowcontrol
status = lynx.SetFlowControl(FTDI.FT_FLOW_CONTROL.FT_FLOW_NONE, 0x00, 0x00);
Console.WriteLine("Failed to set FlowControl for device C (error " + status.ToString() + ")");
Console.ReadKey();
return;
Console.WriteLine("Set FlowControl for device C to None");
//Set read timeout to 5 seconds, write timeout to infinite
status = lynx.SetTimeouts(5000, 0);
// Wait for a key press
Console.WriteLine("Failed to set timeouts (error " + status.ToString() + ")");
Console.ReadKey();
return;
Console.WriteLine("Set SetTimeouts for device C to Read 5 seconds, Write infinite");
//Start our write timer
timerWrite = new Timer(new TimerCallback(Timer_TickWrite), null, 2000, 500);
Thread.Sleep(-1);
//return;
static int ctr = 0;
static void Timer_TickWrite(object sender)
//Need bytes
byte[] bytes = System.Text.Encoding.UTF8.GetBytes(TextContent);
status = lynx.Write(bytes, bytes.Length, ref written);
lynx.Purge(FTDI.FT_PURGE.FT_PURGE_TX);
Console.WriteLine("Bytes written: " + written.ToString() + " " + ctr.ToString());
ctr++;
return;
Thanks for any help you can provide
