FEZ Hydra & WiFi RS21
Please do not curse much, I’m new to using the FEZ …
First, I installed all of the standard version of the assembly for MF 4.1
Launched the hydra, flashing lights tested …
Module is plugged WiFi-RS21 and was the first problem:
Assuming that I did something wrong, I deleted the NETMF 4.1 and install NETMF 4.2 (http://www.tinyclr.com/forum/topic?id=7982)
Then I updated the bootloader and firmware up to 4.2.2 version
The problem with the connection of the WiFi-RS21 module remained
Regardless of the socket 3 or 4 - a problem when connecting to the usb is important.
In addition, there was a second problem in the design studio - the WiFi-RS21 module can not be put in the work area, it show error dialog.
(Using beta 4.2 GHI NETMF)
I tried to manually add a reference to the assembly, I found it in the GAC and tried to manually set, in the end i have third problem - in this class do not have the claimed properties and methods.
Explain, maybe I’m doing something wrong?
Hi Volhv,
I believe that the WiFi-RS21 Gadgeteer module requires use of the FEZ Spider mainboard.
http://www.ghielectronics.com/catalog/product/282
Chris
About this feature is not written in the product catalog, I’ve opted for a set - look at the compatibility of the socket.
I have a WIFI-RS21 module with external antenna (v1.2)
I would like to hear an official explanation of the problem.
@ Volhv - Hiya, it does actually state on the page:
Supported Through GHI Premium Libraries. Open source products and libraries do not support this module.
So will only work currently on Spider
It’s because RedPine requires an NDA to work with the module, and Hydra is open source. RedPine won’t allow GHI to open source the code for working with the module.
