The doc says:
•Operating temperature: 0 to 70°C
Is this a board design for mostly tropical climates or can it do -20C like the other boards?
Thanks.
The doc says:
Thanks.
Rated 0 to 70 as catalog shows.
What kind of problems are we faced if we use Hydra in places with a temperature below zero?
It may or may not work.
Or worse, work erratically.
although a quick polystyrene foam insulation case would make this largely a non-issue.
Does Hydra have a linear regulator onboard? The USB DP doesn’t, right? Easy enough to dissipate some heat from a simple resistor, though, and heat a well-insulated enclosure a few degrees.
