i have a FEZ Hydra with the newest firmware ( with Ethernet ) and a Ethernet ENC28 1.1 Module ( on Socket 3 ).
I want to use the Hydra as a small WebServer, but it doesn’t work. I can’t connect with a WebBrowser.
Now i want to check the connection with a ping from my PC. A ping to the Hydra fails.
In visual sutdio debug window now errors where reported …
If all 3 devices (the hydra, the router/switch and the PC) do not accept a netmask of 255.255.0.0, you will need to use a netmask of 255.255.255.0, and stay on the same class C sub-net (192.168.x.x). So if your computer has a local address of 192.168.1.48, then your hydra should be requesting 192.168.1.23. Is there a reason you wish to use a different class C sub-net? Using that net mask allows for up to 65,025 devices to connect to your network in total, is this needed?
i use the code Mike posted, it works. Dynamic IP works fine. If i want set a static IP (i tried different ips and subnet masks) the internet wasn’t working.
