I have got another question:
I did a firmware update on the fez hydra. (I took the FEZ Hydra Ethernet Firmware)
It seems to be working when I was debugging the code.
But I can’t ping the fez hyra and can not send data over the network.
Even when I connect the fez hydra to my router not all status leds are blinking.
I tried out some network samples on this site.
First of all I checked, that I’ve got an valid IP adress.
After that I setup an Webserver:
using System.Net;
using Gadgeteer.Networking;
using GHIElectronics;
using Gadgeteer;
using System.Net.Sockets;
using System.Text;
namespace Controller.Helper
/// <summary>
/// </summary>
public class Server
/// <summary>
/// Initializes a new instance of the <see cref="Server"/> class.
/// </summary>
public Server(string ip, int port)
Gadgeteer.Networking.WebServer.StartLocalServer(ip, port);
WebEvent sayhello = WebServer.SetupWebEvent("HELLO");
sayhello.WebEventReceived += new WebEvent.ReceivedWebEventHandler(sayHello_WebEventReceived);
Debug.Print("WebServicer initialized.");
void sayHello_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
Debug.Print("WebEventReceived");
The strange thing is, that on my router not all leds are blinking.
Maybe its because of another module, which is connected in socket 4.
(I heard that socket 3 and 4 are sharing the spi-bus)
Hi there, I am looking to connect a Hydra to the Internet. What Port does the ENC28 connect to on the Hydra. I am looking to call a bing service from a Hydra. The ENC28 is not showing up in my Gadgeteer designer toolbox in Visual Studio 2010. I can manually add in the reference to the ENC28 if I know which port it should connect to. Is it Port 3 or Port 4 and is there a conflict as indicated by the last post. Or if no go can somebody point me in the direction of Xbee connectivity using the Hydra. Many thanks.
