@ lty20785 - It is a strong possibility. We have experienced issues while accessing things via the USB 3.0 ports. Try to use a 2.0 port and/or see if you can try on another PC that has Windows 7.
I was able to update the loader with a USB 2.0 port, but I was still having trouble getting it into CLR mode. I tried 2 ways:
“Reboot CLR” of the Fez Config tool, which didn’t quite work and it’s still in loader mode .
although it says success
I tried to update the firmware (despite it’s already up to date). Everything seems normal until it reboots, where fez config would hang there for a few minutes, and then display success. But after that, the hydra would stop working and even fez config can not communicate with it. I had to re-deploy the loader again.
You’re deploying the Ethernet firmware. You do have your Ethernet module connected to the correct socket, don’t you ? The Ethernet firmware does not work (ie a won’t start kind of failure) if you don’t have the Ethernet module connected correctly… perhaps try without the Ethernet firmware to see if that makes a difference to start?
