Thanks for the reply
I checked the following: no pins where bent, I replaced the cable with another one and I still have the same issue.
I changed the connection from connector 3 to connector 4 (Both S connectors). I still have the same issue.
As far as I know I cannot change to non Gadgeteer parts because the Fez Hydra only has Gadgeteer connectors. So any suggestions how to do a non- Gadgeteer setup?
Can I go back to the previous state? That is not possible because the computer was stolen with the original software… I’m working from a back-up / partial rebuild. With my other computer I have moved to VS2013 and the last updates from GHI. I did the necessary firmware updates to the Fez as well (update from 4.2 to 4.3).
Was it working reliable before: the answer was yes but I don’t have the old software anymore. So I have to work from here.
I made a new 4.3 Gadgeteer application in VS2013. I only connect the usb client power modal to connector 2 and EthernetENC28 to connector 4 (all new cables). Also did a simple code implementation (see below). I now get an IP from my DHCP server. That is nice. But after a few minutes the power led start to dim and the same issue of the power LED blinking is back again even with extra power from an external power supply. So any suggestion on what to do next?
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
Debug.Print(“Program Started”);
ethernetENC28.NetworkUp += ethernetENC28_NetworkUp;
ethernetENC28.NetworkDown += ethernetENC28_NetworkDown;
if (!ethernetENC28.NetworkInterface.Opened)
ethernetENC28.NetworkInterface.Open();
ethernetENC28.NetworkInterface.EnableDhcp();
ethernetENC28.NetworkInterface.EnableDynamicDns();
while (ethernetENC28.NetworkInterface.IPAddress == "0.0.0.0")
Debug.Print("Waiting for DHCP");
Thread.Sleep(250);
Debug.Print("My IP is: " + ethernetENC28.NetworkSettings.IPAddress.ToString());
Debug.Print("My Sub is: " + ethernetENC28.NetworkSettings.SubnetMask.ToString());
void ethernetENC28_NetworkDown(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Network Down");
void ethernetENC28_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Network Up");
Found debugger!
Create TS.
Loading start at 20252248, end 2028757c
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0) Assembly: System.Xml (4.3.1.0)
Assembly: Microsoft.SPOT.Time (4.3.1.0) Assembly: Microsoft.SPOT.Net (4.3.1.0)
Assembly: System (4.3.1.0) Assembly: Microsoft.SPOT.Net.Security (4.3.1.0)
Assembly: System.Net.Security (4.3.1.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.43.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.8.1) Attaching deployed file.
Assembly: System.Http (4.3.1.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.43.1.0) Attaching deployed file.
Assembly: GadgeteerApp1 (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.8.1) Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.43.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZHydra (4.3.8.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.EthernetENC28 (4.3.8.1) Attaching deployed file.
Assembly: GHI.Networking (4.3.8.1) Resolving.
GC: 1msec 473784 bytes used, 5817348 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 5817348 bytes
Type 17 (ASSEMBLY ): 40080 bytes
Type 1E (BINARY_BLOB_HEAD ): 433608 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Xml.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Time.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebClient.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.SPI.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Networking.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\EthernetENC28\NETMF 4.3\le\GTM.GHIElectronics.EthernetENC28.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Modules\USBClientDP\NETMF 4.3\le\GTM.GHIElectronics.USBClientDP.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics.NET Gadgeteer SDK\Mainboards\FEZHydra\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZHydra.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Thermostaat\Basics\Ethernet\GadgeteerApp1\bin\Debug\le\GadgeteerApp1.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebServer.dll’, Symbols loaded.
Using mainboard GHI Electronics FEZ Hydra version 1.2
Program Started
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
Waiting for DHCP
My IP is: 192.168.178.59
My Sub is: 255.255.255.0
Network Down
Network Up
