wouldn’t that be easier and most like would allow you to use the existing Driver as is? i have the module here but didn’t have time to try it out so if you do try it please let us now you finding…
Btw how hard would it be to plug your module directly to the enc without using that cable but instead you would use male/female headers…?
This would definitely help bring the cost and time down…
Not hard at all. You cold solder the module directly onto the ENC28J60 board, or you could solder a female header onto the module and plug it in. I’ll be offering the boards here in a couple days, as soon as some shipping materials arrive.
This first batch of boards has the header turned backwards (it’s a recurring theme, as you’ll see soon), but it’s not TOO inconvenient.
No, unfortunately not. I could probably work out a lined-up version, but these eBay modules are not all exactly the same. This particular one is common, but there are other slightly different designs.
Don’t bother. I was just checking. You mentioned you flipped the header? Does that mean the two of the 5mm spaced holes on the module will be exposed for mounting? That’s what I’m shooting for - mounting these on the various 5mm grids plates many of us have.
