Can this code considered faithful to configure the client to the socket module.
using Microsoft.SPOT.Hardware.UsbClient;
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerApp4
public partial class Program
Socket Soc = Socket.GetSocket(4, false, null, null);
Configuration.UsbInterface config = new Configuration.UsbInterface((byte)Soc.SocketNumber, null);
I am not sure exactly what you’re asking us to help with - can you tell us how you set up the Gadgeteer designer? Any errors that you want to understand?
One thing I would ask is, exactly what do you mean as a “client”? What is it that you are going to want to achieve?
From http://www.ghielectronics.com/offers/ you can see that “USB Client” is a part of netmf so therefore should be a part of Hydra’s firmware (but I haven’t confirmed or used it). http://wiki.tinyclr.com/index.php?title=USB_Client is going to be the best reference for USB client. Then there are likely to be examples on the codeshare for some of the pieces you may need.
Again, you answer the question with a very small amount of information. Please, be more elaborate in your answer and you’ll get more help.
I have a Fez Hydra talking to a PC over bluetooth. Does that suit your application? read up on CDC and Serial communications here and you might get some inspiration.
