Hello, I’m assembling a rover and I want to try to use a RPI3 with Fez Hat to handle it.
When I look for the connection I see in the spec schema the Pin V+ noted with a notation of exiting voltage.
On the board (photo) that pin is noted as “Motor Power” and for what I understand could be the pin where place the external power supply for the motor.
Before to connect something in a wrong way I’m asking if someone other had successfully connected it to control some motor.
Marco
