Fez Flea and never ending Interrrupts
I keep getting multiple interrupt calls, so much so that I had to implement code to try and debounce the input.
flag = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PA0);
flag.SetDriveMode(GpioPinDriveMode.Input);
flag.DebounceTimeout = TimeSpan.FromMilliseconds(500);
bool flagLatched = false;
flag.ValueChanged += (s, e) =>
    if (e.Edge == GpioPinEdge.FallingEdge && !flagLatched)
        flagLatched = true;
        flagResolutionThread.Resume();
    else if (flag.Read() == GpioPinValue.High)
Should I be using the pull up or pull down resistor?
can you try this:
    Debug.WriteLine(e.Edge.ToString());
The requirement for a pull up/down resistor depends upon the characteristics of the signal source.
If the signal is supplying proper zero and one voltages, and switching times within specifications, then a resistor is not required. Too much time in the forbidden zone, between one and zero, will cause issues such as you are seeing.
But, for a definitive answer, you would have to tell us how the signal is being produced.
What a truly baffling result. I added a counter as well.
The PowerStep01 stepper drivers are producing the signal; Active Low. Are we thinking that they are constantly toggling the Flag pin? I’d have to break out the scope to find out (sigh).
EDIT: The datasheet says its a latch and does not toggle continuously.
Sounds like a good plan…
Chat GPT says that TinyCLR is internally polling the signal and producing the interrupts. Is that true? It could save me from having to pull out the scope.
Lol and how would chat gbt know what is happening inside closed source code?
That’s what I wanted to confirm. Cuz you’re using the hardware to detect transitions right?
Scope time!
Something was wrong with the board. I’ve reverted to a previous solution.
I’m getting 1 flag interrupt now, which matches what I see with the status lights.
