FEZ.Feather WiFi not working
Hi all,
I’m new to TinyClr and have first my experiences with FEZ.Bit using WiFi connection. That all works very well out of the box.
Now I’ve tried to port the code to a FEZ.Feather board. Using the same code I only changed the GPIO- and SPI definitions from FEZBit to FEZFeather. (I’ve also tried both SPI on Feather)
Definitions are for FEZ.Bit:
//Setup Pins
            var enablePinNumber = FEZBit.GpioPin.WiFiEnable;
            var chipSelectPinNumber = FEZBit.GpioPin.WiFiChipselect;
            var irqPinNumber = FEZBit.GpioPin.WiFiInterrupt;
            var resetPinNumber = FEZBit.GpioPin.WiFiReset;
            var spiControllerName = FEZBit.SpiBus.WiFi;
and for FEZ.Feather:
//Setup Pins
            var enablePinNumber = FEZFeather.GpioPin.WiFiEnable;
            var chipSelectPinNumber = FEZFeather.GpioPin.WiFiChipselect;
            var irqPinNumber = FEZFeather.GpioPin.WiFiInterrupt;
            var resetPinNumber = FEZFeather.GpioPin.WiFiReset;
            var spiControllerName = FEZFeather.SpiBus.Spi4;
On the FEZ.Feather calling networkController.Enable() throws a System.InvalidOperationException.
(An unhandled exception of type ‘System.InvalidOperationException’ occurred in GHIElectronics.TinyCLR.Devices.Network.dll)
As said, on FEZ.Bit all is working as expected.
Both boards are 2.2.0.6500; Visual Studio 2022 on W10 Enterprise.
Please can give anyone an advice what I’m doing wrong?
Thanks in advance
Greetings Juerg
FEZ.Feather-Code (non-working):
using System.Diagnostics;
using System.Net;
using GHIElectronics.TinyCLR.Devices.Network;
using GHIElectronics.TinyCLR.Devices.Spi;
namespace FEZ.Feather_Wifi_Test
    internal class Program
        static string ssid = "mySSID";
        static string pw = "myPW";
        private static readonly NetworkController networkController = NetworkController.FromName
            (SC20100.NetworkController.ATWinc15x0);
        private static void Main()
            // Wifi
            InitWifiModule();
            WiFiNetworkInterfaceSettings networkSettings = new WiFiNetworkInterfaceSettings
                Ssid = ssid,
                Password = pw,
                DhcpEnable = true,
                DynamicDnsEnable = true
            networkController.SetInterfaceSettings(networkSettings);
            networkController.SetAsDefaultController();
            //Wait for IP address
            var isReady = false;
            networkController.NetworkAddressChanged += (a, b) =>
                var ipProperties = a.GetIPProperties();
                Debug.WriteLine("IP: " + ipProperties.Address);
                var address = ipProperties.Address.GetAddressBytes();
                if (address[0] != 0 && address[1] != 0)
                    isReady = true;
            Debug.WriteLine("Enable the network controller.");
            networkController.Enable();
            Debug.WriteLine("Network controller is enabled.");
            while (!isReady)
                Thread.Sleep(100);
            IPHostEntry ip = Dns.GetHostEntry("branscheid-gmbh.com");
            Debug.WriteLine("BIA' IP = " + ip.AddressList[0].ToString());
        private static void InitWifiModule()
            //Setup Pins
            var gpio = GpioController.GetDefault();
            var enablePin = gpio.OpenPin(enablePinNumber);
            enablePin.SetDriveMode(GpioPinDriveMode.Output);
            enablePin.Write(GpioPinValue.High);
            SpiNetworkCommunicationInterfaceSettings netInterfaceSettings =
                new SpiNetworkCommunicationInterfaceSettings();
            var settings = new SpiConnectionSettings()
                ChipSelectLine = gpio.OpenPin(chipSelectPinNumber),
                ClockFrequency = 4000000,
                Mode = SpiMode.Mode0,
                ChipSelectType = SpiChipSelectType.Gpio,
                ChipSelectHoldTime = TimeSpan.FromTicks(10),
                ChipSelectSetupTime = TimeSpan.FromTicks(10)
            netInterfaceSettings.SpiApiName = spiControllerName;
            netInterfaceSettings.GpioApiName = SC20260.GpioPin.Id;
            netInterfaceSettings.SpiSettings = settings;
            netInterfaceSettings.InterruptPin = gpio.OpenPin(irqPinNumber);
            netInterfaceSettings.InterruptEdge = GpioPinEdge.FallingEdge;
            netInterfaceSettings.InterruptDriveMode = GpioPinDriveMode.InputPullUp;
            netInterfaceSettings.ResetPin = gpio.OpenPin(resetPinNumber);
            netInterfaceSettings.ResetActiveState = GpioPinValue.Low;
            networkController.SetCommunicationInterfaceSettings(netInterfaceSettings);
FEZ.Bit-Code (working):
using System.Net;
namespace FEZ.Bit_Wifi_Test
        static string pw = "myPw";
            // Wifi
            InitWifiModule();
                Ssid = ssid,
                Password = pw,
                DhcpEnable = true,
                    isReady = true;
            while (!isReady)
                Thread.Sleep(100);
            //Setup Pins
I think FEZ Feather uses SPI3 for wifi, not SPI4.
to
var spiControllerName = STM32H7.SpiBus.Spi3;
Thanks, works!
We just added
FEZFeather.SpiBus.WiFi
If you want to tweak your code.
