Unexpectedly on the FEZ Duino the command
var rtc = GHIElectronics.TinyCLR.Devices.Rtc.RtcController.GetDefault();
throws exception
On the FEZ Feather and the 20260 Dev Board it works as expected.
Is this a common issue on the FEZ Duino or eventually a faulty board?
Just tried on FEZ Duino and no exception.
FEZ Feather and Duino have same chip so if Feather work then Duino work.
Something with hardware on specific board, I think.
Thanks, that’s what I feared. Bad luck
Is GHI testing the boards for working RTC before they go out for sale?
can you try catch and do again?
I mean try catch and getdefault again.
try {
rtc.Getdefaut();
catch {
rtc.Getdefaut();
If I do
RtcController rtc = null;
try
rtc = RtcController.GetDefault();
catch (Exception ex)
it throws in the statement in the catch block as well
I will check but can you visually inspect or give us a closeup photo of the crystal area?
RoSchmi
April 15, 2021, 10:18pm
#10
Hi @Gus_Issa ,
thanks for your interest, I visually inspected the board, nothing obvious. Fortunately RTC is not essential for my application, so I can live with the board as it is. If it is not alraedy done, perhaps RTC should be tested separately.
