Trying to open PIN PD15 (WiFI CS) results into an exception:
I have updated everything to 2.2.0.6000 (Developer Studio/firmware on device, libraries…).
Example:
Thank you for any assistance.
Example:
Did it work before?
Do you use PD15 somewhere else? This pin is also RTS of UART8, do you use UART8 with HS?
Try a simple project and open only PD15 to see what happened
Thank you for the quick reply. Good news: The simple project is working.
As C# beginner I have now learned that an unused but linked class with a static member
has been the problem:
I have changed there the 15 to 14 as work-a-round, but I will disable/remove the class till
I am ready with my basics doing in the main.
Thank you!!
