I’m trying to calculate a heart rate. I have the counter working but i don’t know how to create a timer. i need it to run for like 10s so that i can calculate the heart rate every 10s ( please note, my code has to be running to while its counting).
Take a look here:
the thing is that the code waits. my code stops running while it wait so how do i keep sampling the heart rate and count time ( together)?
Post your code here.
public static System.Threading.Timer _timer;
CreateTimer();
while(true)
//Continue processing your inputs here, accumulating counters, etc.
public static void CreateTimer()
_timer = new System.Threading.Timer(TimerCallback, null, 10000, 10000);
public static void TimerCallback()
//This method is called every 10 seconds....
OK, Almost there.
Have a class variable or property for counter. Accumulate it in the main while loop. Then in your timer callback get its value and reset the counter to zero.
