Hello, Ive recently purchased a BluetoothBee from [url]http://www.dfrobot.com/index.php?route=product/product&path=45&product_id=193[/url]. Its default baud rate is 9600 bps and if I want to change it I have to put the module into AT mode and execute some AT commands as stated in [url]http://www.dfrobot.com/wiki/index.php?title=BLUETOOH_BEE_(SKU:TEL0023)[/url]. Ive tried connecting to the bee with a terminal program and entering AT -> AT+BAUD8 and also tried to write these command directly to the COM1 port on the device using SerialPort class, but both these approaches failed. What am I doing wrong and is it possibe to reconfigure the bluetooth bee using Fez Domino? The bluetooth module is working and Im able to send and receive data on the Domino but only if it`s SerialPort is created with 9600bps.
If you can use the terminal then you can use domino.
Welcome to the community
