What are JMP1 & JMP2 on the FEZ Connect? I checked the user guide and did not find anything and searching the forums for JMP1 and JMP2 did not return any results.
I suggest that you check the schematics
I did check the schematic, but I can’t find the JMP1 and JMP2 references on the schematic.
JP1 is at C7 on the schematic
JP2 is at B5 on the schematic
What I am referring to is JMP1 and JMP2 labeled on the board between Di5-7 and “Di2 SDA” and “Di3 SCI”.
For the points you referred me to JP2 is for the Di9 jumpers, I think JP1 is pin-less jumpers for the servos.
JMP1 is to connect or disconnect the Wiznet RESET pin to D7
JMP2 is to connect or disconnect the Wiznet INT pin to D4
Thanks!
