I am noticing that when updating the text in a textbox it takes ages to actually re-draw, by which time the message is probably redundant, see the following code:
private void btnCopyLogFiles_TouchDown(object sender, EventArgs e)
try
DateTime startDate;
DateTime endDate;
txtStatusText.TextContent = "Validating dates...";
Invalidate();
if (ValidateForm(out startDate, out endDate))
txtStatusText.TextContent = "Valid dates, exporting now...";
Invalidate();
// Do some thing here which takes about 5-10 seconds
// Text box only seems to show the text below, none of the previous messages are even seen
txtStatusText.TextContent = "Copied log files successfully";
catch (Exception ex)
txtStatusText.TextContent = "Exception raised: " + ex.Message;
Invalidate();
The above code is from a button click, the user has entered two dates and I first validate them, and then do a task which takes about 5-10 seconds.
The issue is the text box isn’t updating before the call to the long running task, which means it looks like nothing has happened after the user selects the button.
Yeah, I had been told that it was slow, but didn’t realise it was that slow ><. If my manager wants UI performance he’ll have to shell out for Glide. Thanks for the comments.
I had experienced such a problem as well. The root of the problem is when you assign a textcontent property, the control recalculates its width and send event to all other controls. This leads to the global ui layout recalculation. Especially when your ui is very complex it takes very much time to get the ui response. In my case I needed to update text about at least 5 times a second and my ui hangs up dramatically. Even updating rtc time value on ui caused freezing. Even setting manually the Width property to a fixed value didn’t work.
But fortunately the solution does exists!
I wrote my own class replacer for Text class. As a result I have one text for clock value (updating once a second) and 3 texts for numeric values (updating ten times a second). And many other ui wpf controls. I run this all on 7-inch display and I’d rather say the ui now flies)).
I’ll post this class at code.tinyclr.com asap and post a link here.
