To help who tries to connect the touchscreen of the TE35 with Cobra III through GXP.
You have to reconfigure the pins of the Touchscreen with the following line of code:
You have to do this with every touchscreen connected to the T port of the GXP connector when you use the FEZ Cobra III.
May be, you also need to calibrate the touchscreen, you can use the documentation from GHI for that:
https://www.ghielectronics.com/docs/162/touch
In my case, I use the following calibration data for my configuration :
```cs]short[] screenX = new short[
{160, 32,32,288,288};
short[] screenY = new short[] { 120, 24, 216, 216, 24 };
short[] uncalibratedX = new short[] { 1820, 725, 713, 3076, 2605 };
short[] uncalibratedY = new short[] { 1822, 893, 2939, 2921, 731 };
Touch.ActiveTouchPanel.SetCalibration(5, screenX, screenY, uncalibratedX, uncalibratedY);
