I am getting a weird pin out error with the Cobra II and its extender board. The SPI socket on the Cobra II board is 6, I am using pin number 6 on socket 6 as a regular Digital Output Pin for an analog to digital(ADC) converter. I am also using the serial interface for another digital to analog converter(DAC) however the ChipSelect for this DAC is pin 6 on socket 7 on the extender board.
The problem is that when the SPI socket is instantiated pin 6 on socket 6 becomes high and outputs 3.3 volts even though the output is supposed to be set to 0V.
The following is the initialization code
//Digital output ADC initialization
private GTI.DigitalOutput _ADCpin;
private GT.Socket _ADCsocket = null;
_ADCsocket = GT.Socket.GetSocket(6, true, module, null);
_ADCpin = new GTI.DigitalOutput(_ADCsocket, pin.Six, false, module);
_ADCpin.Write(false);
//Serial DAC initialization
private GTI.DigitalOutput _DACpin;
private GT.Socket _DACsocket = null;
_DACsocket = GT.Socket.GetSocket(7, true, module2, null);
_DACpin = new GTI.DigitalOutput(_DACsocket, pin.Six, false, module2);
GT.Socket _spiSocket; = GT.Socket.GetSocket(6, true, this, null)
GTI.SPI.Configuration spiConfig = null;
spiConfig = new GTI.SPI.Configuration(false, ChipSelectSetupTime, ChipSelectHoldTime, false, true, ClockRateKHz);
GTI.SPI spiControl = new GTI.SPI(_spiSocket, spiConfig, GTI.SPI.Sharing.Shared, _DACsocket, _DACpin, this);
Right until the last line of code the output for pin 6 on Socket 6 is low however when the last line returns the output becomes high, would anyone know the reason for this?
