Hello. I’m wanting to make a modified FEZ Cobra II board. Does anyone have a version of the design files that includes part numbers, or have a BOM or Parts list?
Thank you.
Thank you.
You can figure it out pretty much easily from the Eagle files:
http://www.ghielectronics.com/downloads/model/FEZ_Cobra_II_Eco_WiFi_EAGLE.zip
http://www.ghielectronics.com/downloads/model/FEZ_Cobra_II_Net_EAGLE.zip
True. I started going through those; however, I figured it was worth asking if anyone already created a BOM because it does take awhile to look up each of the parts.
I’m finding it no so easily done. I went through searching the parts using Eagles Design Link, digikey.com, and Newark.com. So far I only have part numbers for only 15 of the 42 parts.
Does anyone have a BOM for this? GHI, could you possibly supply one as I would be getting the G120 chips from you for any modified boards.
Thanks.
I would try to contact GHI through contact form:
Which parts do not have a number? If you mean SD connector and other connectors, these are sourced from china with no “part number”. What else are you missing?
I need a board with different dimensions and some minor changes. So I’m having the same question.
Maybe a bit of a cheeky question but can GHI provide a BOM of the cobra II board, for building a custom board?
It took me several hours to produce a partial BOM. I don’t see any place to attach it as an excel spreadsheet, so I attached a screenshot. I have 8 unknown items on the board (9 actually, but I know I have a barrel connector part number around somewhere).
Could anyone please assist with identifying the remaining 8 items?
It would be greatly appreciated.
Thanks!
I’ll start creating a BOM later today. It will be based on the cobra II net board. Beside the network part, the BOM’s should be comparable…, i guess
Gus, do you have any part numbers for the remaining parts?
Patrick, how did your BOM creation go?
Thanks.
due to some work issues I had to postpone the creation of the BOM. I’ve rescheduled it for friday… sorry for the delay
@ Hayedid - Please email me the BOM you have so far and I will fill in the blanks for you.
Thank you Mike. I’ve tried to send you an email, but it is bouncing back. Is the email mike@ ghi…? Thank you.
@ Hayedid - michael dot bagnaschi at ghielectronics dot com
@ hayedid & @ Mike: can you share the BOM? It would help me a lot
