I’m trying to do some inline debugging on my Fez COBRA using C# 2010 Express.
I have a real reliability issue, in getting debugging to actually work, and wanted to share an observation or work around.
I have noticed a huge difference in reliability of Visual Studio’s debugger to start when:
a) Press the tool bar Green arrow button (equivalent to Debug> “F5” ) works about 10% of the time (after I activate the FEZ reset button)
b) right click the project in solution explorer, and select Debug > “Step into new instance” , works nearly 100% of the time,
Has anyone else seen this? and know How I can resolve this, and improve “start new instance” reliability?
VS needs to attache the debugger only once and this relies on your device having some idle time so the device can check for VS. If there is no idle time, attaching to the device can fail sometimes. You can help by pressing reset button.
On the other hand, once connected, debugger will work always.
I am using a solution with more than one project in it
I do set the default project as the one I want to run
all projects build successfully.
I’ve also since found
right click project then debug, start new instance works 100% of the time
right click project then debug, step into new instance works 100% of the time
press toolbar green debug arrow -> Error: An error has occurred: please check your hardware. then popup : there were deployment errors do you wish to continue? Y/N
Testing:
I just created a NEW Project in a NEW Solution (Blinking LED) and it ran from F5 (PASS)
I then added another NEW Project the EXISTING Solution (Blinking LED) changed the default startup to this project and ran from F5 (PASS)
I must have somehow corrupted my solution or project:
I’ll try and sort this out today after some Beyond compare work and try and see what a work around would be to repair the problem.
One benefit of right clicking the project and starting a new instance is that it doesn’t need to compile all the other projects before starting up, a real time saver
If the same thing happens after starting a new project and adding your code, then it would be time to start isolating your code sections and finding out where the problem resides.
You could be having a problem with an exception occurring, which puts your system into a bad place.
I Added the previously offending project to the new solution (without any changes to the project) and set it to the start-up project, and ran F5 - (Now a PASS) !!!
Therefore assume something wrong with the Solution File…
Corrupt Solution File:
Microsoft Visual Studio Solution File, Format Version 11.00
# Visual C# Express 2010
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "prj_FEZ Cobra-Glide-Eg", "prj_FEZ COBRA-GLIDE-Eg\prj_FEZ Cobra-Glide-Eg.csproj", "{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "prj_FEZ Cobra-TW Glide Extensions-Eg", "prj_FEZ COBRA-GLIDE Extensions-Eg\prj_FEZ Cobra-TW Glide Extensions-Eg.csproj", "{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "prj_NETMF_FEZ_COBRA", "prj_ALL\prj_NETMF_FEZ_COBRA.csproj", "{C3FDF71C-FD52-4E02-B591-FC08BAD02917}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra -Webcam using image component-1", "FEZ Cobra Console Application_Eg1\FEZ Cobra -Webcam using image component-1.csproj", "{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra -Super Simple Example-3", "FEZ Cobra Console Application_Eg2\FEZ Cobra -Super Simple Example-3.csproj", "{5C466A63-813F-40C7-BBE9-19C312225BD1}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra -Multiple Windows-2", "FEZ Cobra Console Application_Eg3\FEZ Cobra -Multiple Windows-2.csproj", "{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra -Using your own custom keyboard-6", "FEZ Cobra Console Application_Eg6\FEZ Cobra -Using your own custom keyboard-6.csproj", "{AECEA406-8544-4BD0-B47E-B61FC7D86B15}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra TFT Calibration - Reset LCD 480x272", "FEZ Cobra TFT Calibration\FEZ Cobra TFT Calibration - Reset LCD 480x272.csproj", "{73D546E0-B76E-4A35-9172-6CFDE5B96979}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "GHIGraphicalDemo", "FEZ Cobra GHIGraphicalDemo\GHIGraphicalDemo.csproj", "{39F5A21F-4F46-4A77-8749-50545F754393}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra -XML", "FEZ Cobra -XML\FEZ Cobra -XML.csproj", "{D6F06D25-3C39-415D-A3AF-3FB210868DA2}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "WinForms_ScreenExamples", "WinForms_ScreenExamples\WinForms_ScreenExamples.csproj", "{7872CBC3-E49D-41BF-841F-75346DEC4D7C}"
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
Debug|Mixed Platforms = Debug|Mixed Platforms
Debug|x86 = Debug|x86
Release|Any CPU = Release|Any CPU
Release|Mixed Platforms = Release|Mixed Platforms
Release|x86 = Release|x86
EndGlobalSection
GlobalSection(ProjectConfigurationPlatforms) = postSolution
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|Any CPU.Build.0 = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Debug|x86.ActiveCfg = Debug|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|Any CPU.ActiveCfg = Release|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|Any CPU.Build.0 = Release|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|Any CPU.Deploy.0 = Release|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{85BE81F6-1B8E-40D8-A2A5-E7EB06E617B8}.Release|x86.ActiveCfg = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|Any CPU.Build.0 = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Debug|x86.ActiveCfg = Debug|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|Any CPU.ActiveCfg = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|Any CPU.Build.0 = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|Any CPU.Deploy.0 = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}.Release|x86.ActiveCfg = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|Any CPU.Build.0 = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Debug|x86.ActiveCfg = Debug|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|Any CPU.ActiveCfg = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|Any CPU.Build.0 = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|Any CPU.Deploy.0 = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{C3FDF71C-FD52-4E02-B591-FC08BAD02917}.Release|x86.ActiveCfg = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|Any CPU.Build.0 = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Debug|x86.ActiveCfg = Debug|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|Any CPU.ActiveCfg = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|Any CPU.Build.0 = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|Any CPU.Deploy.0 = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{FEFAD8AD-215C-45F0-B43C-ADBC8586F2F1}.Release|x86.ActiveCfg = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|Any CPU.Build.0 = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Debug|x86.ActiveCfg = Debug|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|Any CPU.ActiveCfg = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|Any CPU.Build.0 = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|Any CPU.Deploy.0 = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{5C466A63-813F-40C7-BBE9-19C312225BD1}.Release|x86.ActiveCfg = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|Any CPU.Build.0 = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Debug|x86.ActiveCfg = Debug|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|Any CPU.ActiveCfg = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|Any CPU.Build.0 = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|Any CPU.Deploy.0 = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{010D32D5-6F98-44BD-8AE2-16B73CF6BFB7}.Release|x86.ActiveCfg = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|Any CPU.Build.0 = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Debug|x86.ActiveCfg = Debug|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|Any CPU.ActiveCfg = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|Any CPU.Build.0 = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|Any CPU.Deploy.0 = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{AECEA406-8544-4BD0-B47E-B61FC7D86B15}.Release|x86.ActiveCfg = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|Any CPU.Build.0 = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Debug|x86.ActiveCfg = Debug|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|Any CPU.ActiveCfg = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|Any CPU.Build.0 = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|Any CPU.Deploy.0 = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{73D546E0-B76E-4A35-9172-6CFDE5B96979}.Release|x86.ActiveCfg = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|Any CPU.Build.0 = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Debug|x86.ActiveCfg = Debug|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|Any CPU.ActiveCfg = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|Any CPU.Build.0 = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|Any CPU.Deploy.0 = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{39F5A21F-4F46-4A77-8749-50545F754393}.Release|x86.ActiveCfg = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|Any CPU.Build.0 = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|Mixed Platforms.ActiveCfg = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|Mixed Platforms.Build.0 = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|Mixed Platforms.Deploy.0 = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Debug|x86.ActiveCfg = Debug|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|Any CPU.ActiveCfg = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|Any CPU.Build.0 = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|Any CPU.Deploy.0 = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|Mixed Platforms.ActiveCfg = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|Mixed Platforms.Build.0 = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|Mixed Platforms.Deploy.0 = Release|Any CPU
{D6F06D25-3C39-415D-A3AF-3FB210868DA2}.Release|x86.ActiveCfg = Release|Any CPU
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Debug|Any CPU.ActiveCfg = Debug|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Debug|Mixed Platforms.ActiveCfg = Debug|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Debug|Mixed Platforms.Build.0 = Debug|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Debug|x86.ActiveCfg = Debug|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Debug|x86.Build.0 = Debug|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Release|Any CPU.ActiveCfg = Release|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Release|Mixed Platforms.ActiveCfg = Release|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Release|Mixed Platforms.Build.0 = Release|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Release|x86.ActiveCfg = Release|x86
{7872CBC3-E49D-41BF-841F-75346DEC4D7C}.Release|x86.Build.0 = Release|x86
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
EndGlobalSection
EndGlobal
Working Solution File:
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra Console Application_Standalone", "FEZ Cobra Console Application_Standalone\FEZ Cobra Console Application_Standalone.csproj", "{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FEZ Cobra Console Application_StandAlone2", "FEZ Cobra Console Application_StandAlone2\FEZ Cobra Console Application_StandAlone2.csproj", "{73B6E924-B022-431F-8091-89DD22E7C18B}"
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "prj_FEZ Cobra-TW Glide Extensions-Eg", "S:\.p12-01.Tech Warehouse EVENT TRACKER\SOFTWARE\ALL.NETMF\prj_FEZ COBRA-GLIDE Extensions-Eg\prj_FEZ Cobra-TW Glide Extensions-Eg.csproj", "{ED1672E1-9A48-4FD6-8B73-D7F22EF1D583}"
EndProject
Global
EndGlobalSection
{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}.Debug|Any CPU.Build.0 = Debug|Any CPU
{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}.Release|Any CPU.ActiveCfg = Release|Any CPU
{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}.Release|Any CPU.Build.0 = Release|Any CPU
{B1C2EF28-0A75-4D9B-ACA7-53578C6CE379}.Release|Any CPU.Deploy.0 = Release|Any CPU
{73B6E924-B022-431F-8091-89DD22E7C18B}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
{73B6E924-B022-431F-8091-89DD22E7C18B}.Debug|Any CPU.Build.0 = Debug|Any CPU
{73B6E924-B022-431F-8091-89DD22E7C18B}.Debug|Any CPU.Deploy.0 = Debug|Any CPU
{73B6E924-B022-431F-8091-89DD22E7C18B}.Release|Any CPU.ActiveCfg = Release|Any CPU
{73B6E924-B022-431F-8091-89DD22E7C18B}.Release|Any CPU.Build.0 = Release|Any CPU
{73B6E924-B022-431F-8091-89DD22E7C18B}.Release|Any CPU.Deploy.0 = Release|Any CPU
EndGlobalSection
EndGlobalSection
EndGlobal
