Hello! This’ll be my first post! I’ve got a few minor issues with a squeeky new Cerebus Mainboard (hardware v1.1). I flashed the mainboard firmware late last night, and here’s a dump of the NETMF Deployment Tool’s plugin>debug>show device info.
DeviceInfo:
HAL build info: 4.2.0.0, Copyright Oberon microsystems, Inc.
OEM Product codes (vendor, model, SKU): 255, 0, 65535
Serial Numbers (module, system):
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Solution Build Info: 4.2.1.1, Copyright (C) GHI Electronics, LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.2.0.0
Microsoft.SPOT.Native,4.2.0.0
Microsoft.SPOT.Hardware,4.2.0.0
Microsoft.SPOT.Graphics,4.2.0.0
Microsoft.SPOT.TinyCore,4.2.0.0
Microsoft.SPOT.Hardware.SerialPort,4.2.0.0
Microsoft.SPOT.Hardware.OneWire,4.2.0.0
Microsoft.SPOT.Hardware.Usb,4.2.0.0
Microsoft.SPOT.Hardware.PWM,4.2.0.1
Microsoft.SPOT.Net,4.2.0.0
System,4.2.0.0
Microsoft.SPOT.IO,4.2.0.0
GTM.GHIElectronics.Joystick,1.0.1.0
Gadgeteer,2.42.0.0
GHI.OSHW.Hardware,4.2.1.0
System.Http,4.2.0.0
Microsoft.SPOT.Net.Security,4.2.0.0
GHIElectronics.Gadgeteer.FEZCerberus,1.0.2.0
Microsoft.SPOT.Touch,4.2.0.0
GTM.GHIElectronics.LED7R,1.0.0.0
GTM.GHIElectronics.UsbClientDP,1.0.0.0
GadgeteerApp1,1.0.0.0
System.Net.Security,4.2.0.0
System.IO,4.2.0.0
I have a fresh install of VS10 Express followed by NETMF SDK 4.2 (RTM QFE1), and the beta GHI NETMF v4.2 and Gadgeteer Package. All the installations went just fine with no issues.
So here’s the questions…
The UsbClient SP module isn’t available in the toolbox when initially building the graphic Program.Gadgeteer, so I’ve used the UsbClient DP instead. It seems to work fine, but I wonder if I’ve installed something incorrectly? Perhaps the SP was omitted in the GHI NETMF v4.2 package for some reason?
All programs generate a warning/error
“A first chance exception of type ‘System.NotSupportedException’ occurred in Microsoft.SPOT.IO.dll
Using mainboard GHI Electronics FEZCerberus version 1.1”
The programs all run fine, but I can’t solve the reason for the warning…
Other than these little quirks, everything works great and I’m having a blast learning C#. Thanks for a great product!
