I recently attached a Digi Xbee Wifi Module to the Fez Cerbuino that has the RP-SMA connector. The connector is too close to the USB host port. It’s so close that I have to take of the lock washer and nut just to fit it to the board. I had also purchased a Large RP-SMA antenna which definitely won’t fit.
This is just for someone’s future reference. I think the boards should only come with the vertical Usb Host.
If anyone has any ideas how I can fix this (even with solder) I’d be grateful.
