Loader (TinyBooter) version information:
4.2.6.1 on this computer.
4.2.6.1 on this device.
The Loader (TinyBooter) is up to date. <<<
Firmware (TinyCLR) version information:
Firmware (TinyCLR) Version: Not available.
The device is in Loader mode.
Click on ‘Reboot CLR’ under the Advanced menu to reboot the device.
I clicked Reboot CLR then tried Firmware Updater.
It still says The device is in Loader Mode. Version 4.2.6.1 but gives the option to continue.
Device will be updated automatically! DO NOT disconnect or turn off the device!
Connecting to device…
Cerb-Family_Gadgeteer is connected
Please wait while rebooting in TinyBooter mode…
Found TinyBooter version: 4.2.6.1
Hi Mike, if you are deploying the Etthernet firmware, make sure you have the ENC28 module connected - since you have a Cerbuino Bee, make sure it’s in Socket 1 when you apply the firmware update. Does that help?
I ran MFDeploy from C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Tools
Selected Config.hex and Firmware.hex from C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\FEZ Cerb Family\Firmware\Non Ethernet
And received Error unable to deploy to device while erasing sector 0x08010000
How are you connecting the Cerbuino to the PC? Of what I mean, is it through a hub? Is it through a USB 3 port? Try to switch ports, and/or to another computer if you can. There seems to be an issue with NetMF and USB 3.
