Just received this board and I’m looking for some getting started docs. i.e. What files to download and where to get them. I guess just some normal getting started information like I’ve received with other boards I’ve purchased. I must be overlooking something, doing some searches I find bits and pieces but nothing very comprehensive. I have a lot of experience with .net, c# and I’ve worked with .NETMF and I have 4.2 installed. I’ve also worked with Arduino boards, so I’m ok there. So, I’m looking for information on how it all relates to the Cerbuino board.
You are right. I checked his previous 4 replies and he is pretending to answer :wall: His account is completely deleted now along with all related posts
Anyway, when I run the installer (setup), I’m getting an exception on “GHI .NET Gadgeteer SDK v4.2”. If I run it by itself, it just stops after running it. If I allow the bootstrapper (setup) to launch it, I get a .net unhandled exception
“Length cannot be less than zero. Parameter Name: Length”
I searched but couldn’t find any information this.
@ ericO - Checking/loading new firmware should be the first step. It is preloaded, but with the version that was available when board was made. Few new versions were released since then.
@ Architect - sounds good. Any thoughts on the installer exception? Sounds like its missing an expected parameter. Is there a config file or can you pass the installer arguments?
@ Architect - I extracted everything to a folder, seemed ok. I thought about permissions so I ran setup as admin. I did the same when I ran it by itself, I’ll check event viewer to see if anything is in there.
@ Architect - Checked Event Viewer but no errors. I see other messages that the installers created but no errors. I guess I can try to download the zip and try again, not sure what else to do.
@ Architect - Good news! I downloaded the zip again, and re-ran the install and all went well. Corrupt package maybe, who knows. Anyway, thanks for the assistance with this.
