I’ve done that, and as I explained it works fine under VS, but when run with just connected to power, it doesn’t start. I’ve tried both connected to my laptop for power, as well as on a battery supply The red power LED on the FEZ Cerberus is on, so I know it has power. If it’s possible to attach a file to this forum thread, then it will be the blinky project for your perusal.
The TinyCLR Config program shows the Deivce as Cerb, the Name as Cerb and the Version as 0.6.0.0.
Interesting, when I click the Reboot button in TinyCLR, then the blinky program starts up.
In DeviceManager, there is one Universal Serial Bus device: Cerb.
It shows some interesting messages in the Events tab of the Cerb properties window:
2017-12-31 15:15:20 Device not migrated
in the information window:
Device USB\VID_1B9F&PID_0110\6&1eed20e4&0&3 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_10C4&PID_800A\106161
Class Guid: {4D36E978-E325-11CE-BFC1-08002BE10318}
Location Path: PCIROOT(0)#PCI(1D00)#USBROOT(0)#USB(1)#USB(3)
Migration Rank: 0xF000FFFFF0000033
Present: false
Status: 0xC0000719
The next entry in events, with the same timestamp:
2017-12-31 15:15:20 Device Configured (winusb.inf)
Device USB\VID_1B9F&PID_0110\6&1eed20e4&0&3 was configured.
Driver Name: winusb.inf
Class Guid: {88BAE032-5A81-49F0-BC3D-A4FF138216D6}
Driver Date: 06/21/2006
Driver Version: 10.0.16299.15
Driver Provider: Microsoft
Driver Section: WINUSB.NT
Driver Rank: 0xFF2000
Matching Device Id: USB\MS_COMP_WINUSB
Outranked Drivers:
Device Updated: false
Parent Device: USB\VID_8087&PID_0020\5&33b10b42&0&1
and the third entry is
2017-12-31 15:15:20 Device started (WINUSB)
Device USB\VID_1B9F&PID_0110\6&1eed20e4&0&3 was started.
Service: WINUSB
Lower Filters:
Upper Filters:
