Hi all,
Today I received my FEZ Cerberus and N18 display.
After updating firmware ready to give it a try.
Took the sample from http://www.tinyclr.com/codeshare/entry/636 and copied the example program (below)
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace N18_Test
public partial class Program
GTM.GHIElectronics.Display_N18 display_N18;
timer.Tick +=<tab><tab>
timer.Start();
display_N18 = new GTM.GHIElectronics.Display_N18(5);
display_N18.Initialize(4000);
// Usage example #1. Simple Graphics support.
display_N18.SimpleGraphics.Clear();
display_N18.SimpleGraphics.DisplayText("Hello World!", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.Red, 5, 5);
// Usage example #2. Passing a Bitmap to the driver.
Bitmap picture = Resources.GetBitmap(Resources.BitmapResources.LogoFSE_zwarte_achtegrond );
display_N18.DrawBitmap(picture);
// Usage example #3. Passing raw bitmap information to the driver, placing it at a certain location.
byte[] newRender = new byte[100 * 100 * 4];
Bitmap pic2 = Resources.GetBitmap(Resources.BitmapResources.LogoFSE_zwarte_achtegrond);
Array.Copy(pic2.GetBitmap(), newRender, newRender.Length);
display_N18.DrawBitmapRawData(newRender, 0, 0, 100, 100);
When run, the mentioned exception occurs in the driver, in the function below, at the line
GTM.Module.Mainboard.NativeBitmapConverter(/bitmapbytes/bitmapData, vram, Mainboard.BPP.BPP16_BGR_BE);
The debugger states NativeBitmapConverter() is null?
public void DrawBitmapRawData(byte[] bitmapData, uint x, uint y, uint width, uint height)
SetClippingArea(x, y, width-1, height-1);
WriteCommand(0x2C);
if(vram != null)
if (vram.Length != (width * height * 2))
vram = new byte[width * height * 2];
GTM.Module.Mainboard.NativeBitmapConverter(/*bitmapbytes*/bitmapData, vram, Mainboard.BPP.BPP16_BGR_BE);
DataWrite(vram);
SetClippingArea(0, 0, Width, Height);
Is there a bug in the driver?
