David_H
February 20, 2013, 5:29am
1
I am having a problem with hardware handshaking using socket 2. To help resolve the problem I have written a simple test program. I can see data coming out of the TX pin and read it correctly; the output for the TX pin can be disabled/enabled by toggling the CTS pin as expected. What I cant see is the RTS pin changing state using an oscilloscope: this is cause of my problem. I need to use the RTS line to control data direction on a RS485 (ADM485) device. I have tried a 4k7 pull-up resistor to see if the line is been driven low since this is its state when running the program: the line is been driven low.
Can anybody help!
using System.IO.Ports;
using GT = Gadgeteer;
namespace SerialTestApp.Classes
class TestRs232
private Joystick _JoyStick;
private RS232 _RS232;
private GT.Mainboard _Mainboard;
internal TestRs232(Gadgeteer.Mainboard mainBoard, RS232 comsPort,Joystick joystick )
_RS232 = comsPort;
_JoyStick = joystick;
_Mainboard = mainBoard;
_RS232.Initialize(9600, GT.Interfaces.Serial.SerialParity.None, GT.Interfaces.Serial.SerialStopBits.One, 8, GT.Interfaces.Serial.HardwareFlowControl.Required);
_RS232.serialPort.Open();
_JoyStick.JoystickPressed += new Joystick.JoystickEventHandler(_JoyStick_JoystickPressed);
_JoyStick.JoystickReleased += new Joystick.JoystickEventHandler(_JoyStick_JoystickReleased);
_Mainboard.SetDebugLED(_RS232.serialPort.UsingHardwareFlowControl);
void _JoyStick_JoystickReleased(Joystick sender, Joystick.JoystickState state)
_Mainboard.SetDebugLED(false);
void _JoyStick_JoystickPressed(Joystick sender, Joystick.JoystickState state)
SendData();
_Mainboard.SetDebugLED(true);
private void SendData()
byte[] data = new byte[] { 0x01,0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09 };
_RS232.serialPort.Write(data);
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
David_H
February 20, 2013, 5:40am
3
Thanks Ill remember that!
class TestRs232
_RS232 = comsPort;
SendData();
You can edit your original post (pencil button). Select your code and press grey “1010” button. All it does is wraps selected text with code tags.
Much better. I am not exactly 100% sure, but I remember seeing something about hardware handshaking not supported in current firmware. I would also search for threads that have RS485 you might find something usefull there:
http://www.tinyclr.com/forum/search?q=RS485
Welcome to the forum!
David_H
February 20, 2013, 5:59am
6
Thank’s I’ll take a look!
We did improve this a bit but handshaking does not work perfectly. The smaller memory caused some issues
This maybe visited in the future but it is a low priority item.
Welcome to the community.
David_H
February 20, 2013, 7:32am
8
Thanks. Thats save me some time: Ill look at other solutions.
